Options on Replacing Flat Roof After Poor Work
Rohit15
by Rohit15 » Fri Mar 06, 2020 4:14 pm
I need advice on flat roof replacement. A cowboy builder built a fibre glass flat roof with Velux window and incorrect slope about 6 months ago. The problem I am having with the roof is minor leaking especially around eaves and Velux due to incorrect slope and job was done poorly.
Recently a roofer suggest following:
Option 1: Rip off existing roof, correct slope and change Velux window to roof dome and redo fibre glass.
Option 2: . Re do a new structure
timber deck roof to 15 degrees
pitch roof. Apply 18mm osb
board and GRP fibreglass
system with a top coat in grey.
Sides of the extension timber
deck it and supply a plastic fascia
board
Which option would be better? Can someone please advise me?
thedoctor
Re: Options on Replacing Flat Roof After Poor Work
by thedoctor » Wed Mar 11, 2020 8:36 pm
On looking, both options are pretty much the same. I would rip it all off and start again with a minimum fall of ½ an inch per 12 inches of run. IE 1 in 24. The minimum recommended by Building Regulations is 1 in 40.
I would use 3mm rubber rather than GRP as it’s guaranteed for 40 years and will move if the roof moves, which they always do.
I would create upstands for a window to guarantee water-tightness using windows like this https://www.sterlingbuild.co.uk/product ... rb-55x78cm
Hope this helps
B4Less
Location: 3rd Floor, 207 Regent Street, London, W1B 3HH
by B4Less » Mon Jan 11, 2021 5:02 pm
Both options would work. In this case, it is all about getting the correct slope. Once you have that right everything else should be fine. If I had to choose an option well then option 2 would be what I would go for. It's more comprehensive.
It is currently Sun Nov 24, 2024 5:16 pm
