Tips on how to Batten off Internal Vaulted Ceilings and Timber Walls
conradkr
by conradkr » Mon Mar 09, 2020 9:41 am
Hi All
I am busy insulating a 100 square metre room with vaulted ceilings. The roof has four diffreent pitches of roof (neighbours objected to planning in a BIG way - so we had to go this route).
I am due to complete insulation this week and now need advise on the easiest way to batten off the internal roof trusses to prep them for plasterboarding (which i am also doing!).
SPEC OF THE PROJECT :
    Timber frame
    100 sq metre open plan room
    Vaulted ceilings with 4 different pitches
    Architect & structural engineer : specified 50x50 timber battens & all other specs used.
WALLS :
Timber frame (height 226)
insulation
To then be covered with 9mm OSB
Battened off with 50x50 timber battens to create service void
12.5mm Plasterboard to finish[/list]
ROOF
Insulation
50x50 battens to compress the h control insulation and create service void
Now the bit i need help with: i need to know the easiest and quickest way to batten off these walls and roof. I have never done it before and want to ensure i do this correctly and in the most efficient way possible
I have attached pictures and noted how i think i need to do this - any advice is much appreciated ! Wall battens shown in red, roof battens shown in yellow and plasterboard shown in green
I have marked out the way I THINK i should do this and just need confirmation this IS the correct way to do things. <br /><br />WALLS:<br />I assume I place battens around the window frames first (making sure i notch out where the window straps are to keep things level<br /><br />2) Then place battens around the entire perimeter of the frame (top and bottom) and then lay my battens every 400mm to pick up the plasterboard)   <br /><br />3) Does it matter if i lay the battens horizontally or vertically? If i go vertical (and follow the timber frame studs) then do i HAVE to do the same on the <br />roof?<br /> <br />ROOF <br />As you can see there are some complicated angles here <br /><br />1) Once again i assume best course of action is to go horizontal every 400mm ? <br /><br />2) On the hips joins how far across should my batten be? I mean do i leave a gap or do i try make both battens meet up by cutting the batten to the shape of the hip join?<br /><br />would ypou suggest horizontal or vertical battening on this roof - please remember i have to plasterboard this roof so i am looking for the solution which makes plasterboard easiest and will give me the best finish once done <br /><br />all help greatly appreciated
WALLS:
roof?
ROOF
It is currently Wed Jan 08, 2025 5:50 am
