New Washing Machine Fitting for Integrated Machine
Gemsclamp
by Gemsclamp » Sun Mar 15, 2020 10:29 am
Hi hoping someone can help, have a new house, which doesn’t currently have a washing machine, have been told that an integrated washing machine should fit, but when removing the cupboard that is there we found pipe work behind, and want to be makesure before ordering that one will fit, the unit space is standard, and looking at an integrated machine. Please see attached image of pipe work behind to see if will fit, the bottom pipe sticks out about 5cm including the skirting board, the others around 3cm. Thanks
Re: New Washing Machine Fitting for Integrated Machine
by stoneyboy » Fri Mar 20, 2020 4:09 pm
Hi Gemsclamp,
You need to get professional help with this, the pipework could all be part of your heating system and of no use for fitting a washing machine.
Regards, S
It is currently Sun Nov 24, 2024 5:26 am
