Issue With UPVC Handle Replacement and Removing Rod
scottydog8183
by scottydog8183 » Sun Mar 22, 2020 11:05 pm
I'm having issues replacing a defective handle on my upvc window. The handle became defective so I bought a replacement. The handle had became detached from the rod that goes into the window. Unfortunately, the rod is now stuck in the window, I think it's rusted into the mechanism. I've tried wd40 without any luck.
Any advice would be much appreciated
Re: Issue With UPVC Handle Replacement and Removing Rod
by stoneyboy » Tue Mar 24, 2020 12:07 am
You have no option but to get the shaft out - without damaging the closing mechanism. More wd40, a light tap with a hammer to break the rust/corrosion and pull out. You may need mole grips to grip the shaft.
Regards S.
It is currently Sun Dec 22, 2024 2:27 pm
