Leaking End Cap Bleed valve
mcaddy
by mcaddy » Mon Mar 23, 2020 10:04 am
I think I've tracked a leaking heating system down to an end cap air vent. It's not been coming out at a fast rate so mostly evaporating as it runs down the hot pipes. I've tightened but this doesn't seemed to have halted the continued loss of pressure. I caught it the other day with a bead of water around the screw thread. So suspect keen to get it sorted before all the shops are shut and I'm paying over the odds for parts.
I've found what I believe to be a direct replacement
https://www.toolstation.com/air-vent-ca ... nMQAvD_BwE
would it be possible to replace just the screw cap and leave the fitting in place or will I have to replace the whole component.
If replacement is the answer is there a compression fitting option as I've limited experience of soldering and although I understand the theory and have most of the tools, I'm probably best not to start with a vertical fitting.
If I am replacing is there a better / upgraded solution I ought to be considering.
TIA
Re: Leaking End Cap Bleed valve
by stoneyboy » Tue Mar 24, 2020 12:02 am
Hi mcaddy,
These bleed valves have a rubber washer in them that over time perishes.
Buy a new one, depressurise your system, then either replace the cap (if it has the same thread) or fit the washer from the new cap into the old one.
It is currently Sun Nov 24, 2024 11:19 am
