Ridge tiles
polypody
Ridge tiles
by polypody » Sat Mar 28, 2020 4:13 pm
Some of the mortar between each ridge tile on our gabled roof is missing. Viewed from the ground the tiles do not appear to be loosened & the loft appears watertight but I was wondering is this a job, re-mortaring between the tiles, that needs doing sooner than later please?
Re: Ridge tiles
by stoneyboy » Mon Mar 30, 2020 12:11 am
Hi polypody,
Unless the ridges are loose or you have water ingress I would suggest you leave well alone.
Making good would involve raking out loose mortar, soaking the joints and then repointing.
Regards. S
polypody
Re: Ridge tiles
by polypody » Mon Apr 27, 2020 11:35 am
Many thanks stoneyboy.
It is currently Fri Nov 22, 2024 3:14 pm
