What's the Minimum Thickness for Bonding Plaster?
Kenzo1234
by Kenzo1234 » Wed Apr 01, 2020 4:05 pm
Hi does anyone now if there's a minimum thickness for bonding plaster. Any help would be appreciated. Cheese
George441
Re: What's the Minimum Thickness for Bonding Plaster?
by George441 » Sun Apr 05, 2020 8:53 am
Let us know where you should like to Plaster?
Anyway, If it's your ceiling then you need 7 or 8 mm undercoat plaster + finish coat layer 1.5 or 2mm and if it's your walls then 10 or 11 mm undercoat plaster + finish coat is same as the ceiling option 1.5 or 2 mm. that's the minimum.
It is currently Sun Nov 24, 2024 6:07 pm
