Fitting a Climbing Hangboard
PaddyW
by PaddyW » Sun Apr 05, 2020 7:21 pm
I was planning to fit a resin hangboard (a piece of climbing equipment that would attach by two bolts and would need to support a person's weight) to the hundred year old brickwork above my back door. However, I'm not sure what the risks of cracking a brick or similar damage would be when drilling a hole into the middle of two of these vertical bricks (image attached) nor whether there'd be a risk of damage from my body weight pulling straight down on this specific brick arrangement. I reckon it's probably fine, but I'd like a second opinion before I take a drill to my house. Any views?
Re: Fitting a Climbing Hangboard
by stoneyboy » Sun Apr 05, 2020 11:30 pm
Hi paddyw,
If you try bolting into the bricks using plastic plugs or expanding bolts there is the possibility of cracking the bricks. Once you have drilled the holes (make them bigger than the bolts) use some 2-part anchor-fix but follow the instructions.
Regards S.
PaddyW
by PaddyW » Mon Apr 06, 2020 5:46 pm
Thank you! Would there be any other issues that you'd anticipate with this plan?
by stoneyboy » Mon Apr 06, 2020 10:46 pm
Hi paddyw,
Provided the brickwork around the area you will be bolting into is sound there should not be a problem.
Regards S.
It is currently Sun Dec 22, 2024 8:53 am
