Removing Compacted Roots From Rain Drainage
Donskiboy
by Donskiboy » Mon Apr 13, 2020 5:38 pm
I have a 1960's bungalow which has a slope in the back garden. The rear enclosed ground drain from the roof gutter down pipe is blocked as before I owned the property someone decided to put a brick flower bed next to the drain, the roots from the bed have blocked the drain. I've been trying to unblock it with drain cleaner and a Karcher drain clearer hose and only managed to get about 8 inches past the bend, the water is draining but very slowly, any ideas on what I can use to get out the compacted roots? Also I'm assuming I've got a soak away as I've put a hose down the other 2 down pipes and they drain OK but they're not connected to the main bathroom /kitchen drain (had inspection cover up).
Re: Removing Compacted Roots From Rain Drainage
by stoneyboy » Mon Apr 13, 2020 11:54 pm
Hi donskiboy,
You will probably have to dig out the drain run to solve this.
Regards S.
Donskiboy
by Donskiboy » Tue Apr 14, 2020 9:22 am
That would be my last resort as it's in concrete.
Donskiboy
by Donskiboy » Tue Apr 14, 2020 3:21 pm
Managed to clear the blockage with a 6ft length of plastic curtain rail.
Donskiboy
by Donskiboy » Tue Apr 14, 2020 4:27 pm
Assuming as the rainwater is not going down the sewer that it runs into a soakaway, so hopefully I'll get some money back from Southern Water.
It is currently Tue Dec 03, 2024 8:42 pm
