Lintel for Staggered brickwork return
Mick Dewane
by Mick Dewane » Fri Apr 17, 2020 4:55 pm
Hi. We are going to be moving in to a property, that we would like to open up the rear load bearing wall. The problem is that the brickwork has a 250mm/10inch staggered return. Please see the drawings. The question is can a steel Z shaped lintel ( Preferred ) or a H shape lintel do the job required. Or is there a better method of doing the work, to meet Building regulations. Thank You.
_____ _____
| |_____ ______
Photo's will not load. Above is rough outline of the building. 5.650 metres wide. Opening to be 3.950 metres wide. By taking out the Z shaped Brickwork in the centre. There is already a Conservatory built on the outside, of this exterior wall shape.
It is currently Sun Dec 22, 2024 3:56 pm
