Advice on Rear Exterior Bricks and Repair Please
JamesD20
by JamesD20 » Mon Apr 20, 2020 7:51 pm
Hi. I've recently moved into a lovely home only I've started to wonder about the bricks on the rear exterior wall. The house was built around 1950 and the windows and patio doors have been replaced with uPVC ones. Above both the window and the patio door their seems to be small gaps going in a vertical zig zag direction which I guess is the fact their is no lintel or its failed. I've attached the photos and would welcome someone to confirm? I understand I could purchase and install helifex if that's the case?
Secondly some of the bricks are rather rough looking though I'm not sure given the age of the house whether this would be normal or be viewed as damaged and therefore should be replaced? The house isn't damp and otherwise okay but I don't want to leave it to get worse. I would get a surveyor in but obviously can't until lockdown is over. Thanks.
Re: Advice on Rear Exterior Bricks and Repair Please
by stoneyboy » Tue Apr 21, 2020 11:26 pm
Hi jamesd20,
Looks very much as though there were issues when the windows were replaced an bodge repairs have been carried out.
The defective brickwork above the window really needs removing and an angle Linton fitted. The good brickwork will need supporting with a couple of strongboys.
JamesD20
by JamesD20 » Wed Apr 22, 2020 7:23 pm
That's great, thanks stoney for responding and your response, grateful. I'll definitely follow this up.
It is currently Sat Nov 23, 2024 4:08 pm
