Replacing Bathroom Extractor & Light - Wiring Question
Ryanfozzie
by Ryanfozzie » Tue Apr 21, 2020 3:46 pm
Good afternoon!
Hope everyone is safe and well. First time posting - apologies for any mistakes!
I'm replacing a old in line extractor (the type that included the light in vent and couldn't extract air even if it tried - it was useless) and replacing it with a Manrose MF100T. The good news is that the extractor is a straight swap Live, Live Permanant, Netural.
As you can see from the attached, the wiring is a bit of a mess as there was another connection to the halogen light that will not be used anymore. Rather than leaving a live wire, I would like to do this correctly.
From my understanding, I need to do the following (based on the attached photo of the current situation).
Current Lighting Wiring
Connect the lives into 1 X 4 Way Compact PushWire Connectors
Connect the neturals into 1 X 4 Way Compact PushWire Connectors
Connect the earths into 1 X 4 Way Compact PushWire Connectors
I can then remove the extra 'spur' as such that was for the light in the vent and pop it all in a nice junction box.
Sorry if this does not make any sense!
Thanks! :)
Re: Replacing Bathroom Extractor & Light - Wiring Question
by Mr White » Tue Apr 21, 2020 8:16 pm
It makes no sense what so ever.
The "push in connectors" are called Wago connectors.
I can only suggest that if you want to remove an existing light you follow its cable back to your junction and remove its cable from there.
It is currently Sat Jan 11, 2025 6:22 am
