Corner Seating Area Outdoor Furniture Project
Nixy999
by Nixy999 » Wed Apr 22, 2020 6:57 pm
Hi folks.
Wasn’t exactly sure which forum this best fitted.
I’m looking to make a corner seating area for a raised patio which will be part painted and part stained. Firstly, am I best using tantalised wood which has either been allowed to dry or treated with the appropriate sealant or is untreated kiln tried softwood okay if painted/stained and sealed correctly?
Secondly what paint, stain, sealant would you advise. It is like this will remain outdoors year round.
Thanks in advance
Nick
Re: Corner Seating Area Outdoor Furniture Project
by stoneyboy » Thu Apr 23, 2020 10:54 pm
Hi nixy999,
I would not recommend using softwood for your project. Even if you use tantalised timber some areas (like joints) will probably start to deteriorate within 2/3 years.
If you can afford it you are better going for a hardwood.
Always treat the timber using some form of solvent based preservative.
Nixy999
by Nixy999 » Thu Apr 23, 2020 11:01 pm
Thanks S. Will look into it.
It is currently Fri Nov 15, 2024 1:27 am
