3 Metres of Channel Drainage Installation
Danbar7
by Danbar7 » Sat Apr 25, 2020 12:52 pm
I’m looking to install 3m of channel drainage to pick up the rainwater from a new pitched roof and take to an existing gulley.
I’ve got a 9 inch grinder to cut concrete, looking for advice on how far to dig down and if I have to put a concrete bed below the channel?
I’m not a plumber but not shy of DIY.
And advice is welcome
Re: 3 Metres of Channel Drainage Installation
by stoneyboy » Sat Apr 25, 2020 11:20 pm
Hi danbar.
Drainage channel is usually about 100mm deep so you'll probably have to cut as deep as you can with your grinder, break out the bottom and lay a weak concrete mix to bed the channel.
It is currently Tue Dec 24, 2024 12:19 am
