Connecting Speedfit to Tap Connector
martynhsmith
by martynhsmith » Mon Apr 27, 2020 11:48 am
I'm going round in circles - need to move a sink - sorted out everything
except
the taps have two of these flexible pipes like this
https://www.screwfix.com/p/flexible-tap-tails-10mm-x-15mm-x-300mm-2-pack/4565g (if that's standard)
and I want to connect them to speedfit pipe
I could buy this - https://www.screwfix.com/p/jg-speedfit-push-fit-flexible-tap-connector-hoses-15mm-x-x-300mm-2-pack/2475g
But what I really want is a connector
I don't think its this https://www.screwfix.com/p/jg-speedfit-plastic-push-fit-straight-tap-connector-15mm-x/17338
as that looks like the wrong '*******'
Can someone help ?
Re: Connecting Speedfit to Tap Connector
by stoneyboy » Tue Apr 28, 2020 10:19 pm
Hi Martynhsmith
Assuming you are using 15mm Speedfit the flexible connectors for the tap will fit straight onto the Speedfit pipe but don't forget to use inserts in the pipe..
martynhsmith
by martynhsmith » Wed Apr 29, 2020 10:11 am
Thank you
It is currently Tue Dec 24, 2024 2:09 am
