Can I replace this fused spur with another socket?
Chip_Bored
by Chip_Bored » Mon Apr 27, 2020 1:57 pm
Hi All
I'm going through my house replacing all the switches and sockets and came across this (fused spur I think it's called) next to a downstairs fireplace. It shares the same back box as the socket to the left and is fed from that socket (and only connected to that socket). I assume it had a function when there was a back boiler in the fireplace. Can I just remove this fused spur (but leave the wiring) and replace it with another single socket, or remove the wiring and fused spur and replace the single socket with a double?
Thanks in advance
Re: Can I replace this fused spur with another socket?
by Mr White » Mon Apr 27, 2020 10:08 pm
A double socket will not fit as that back box is designed to have two single items. (There is a "support rail" in the middle which would prevent you putting in double socket)
Another single socket it is then.
Chip_Bored
by Chip_Bored » Mon Apr 27, 2020 11:25 pm
Thank you Mr White
It is currently Sat Nov 23, 2024 4:09 pm
