Easy Fix Bracket for Shower Valves - Different lengths?
John B
by John B » Thu Apr 30, 2020 9:09 am
I have ordered a new bracket for our shower, however the chrome threaded pieces that screw onto the wall bracket,which the shower fittings then screw onto are different lengths. I would be grateful if anyone could tell me if this is correct and if so why, and which should go on which pipe!
Thanks in advance
Re: Easy Fix Bracket for Shower Valves - Different lengths?
by stoneyboy » Thu Apr 30, 2020 10:42 pm
Hi Johnb,
I assume you are asking about a bracket for a bar type shower which mounts behind the tiles. If so then the threaded adaptors should be the same length.
John B
by John B » Fri May 01, 2020 8:45 am
Thank you, I assumed that was probably the case!
It is currently Tue Dec 24, 2024 1:21 am
