Help needed to remove door (UPVC) handles to replace multipoint lock
LeeBob21
by LeeBob21 » Wed May 06, 2020 6:45 pm
Hi there,
I hope i'm in the correct thread.
I'm really struggling to remove the door handles on my front door so that I can replace the gearbox.
The problem is I can't remove the handles. I've removed all the screws from the multipoint lock and the cylinder. Now all that remain are the door handles. I looked for a screw under the handle and on the face plate but nothing.
I've included some photos for clarification. If more are needed please ask and i'll get them right away, thanks.
Re: Help needed to remove door (UPVC) handles to replace multipoint lock
by stoneyboy » Wed May 06, 2020 10:34 pm
Hi leebob21
Assuming there are not fixing screws on the opposite side to your picture you will probably need to carefully prise off the chrome cover which is like a capping over the long thin part of the handle. This may only be one side and removal should expose the fixing screws.
It is currently Sun Dec 22, 2024 2:08 pm
