Insulating a shed floor that is currently in place
jcwads
by jcwads » Tue May 26, 2020 4:03 pm
Hello,
I have insulated my shed with celotex board. However when it comes to the floor, the shed is already installed and I cant uproot it. It is sat on a concrete bass with wood panels as the floor presently.
I have about 3.5cm to play with but my options are limited. Can you lay celotex and then some kind of hard floor directly on top of it? I dont have the luxury of joists that you can insulate between and then cover...
Re: Insulating a shed floor that is currently in place
by stoneyboy » Tue May 26, 2020 10:41 pm
Hi jcwads
Lay a DPM on the concrete, 25mm celotex and that leaves you 10mm for flooring.
It is currently Sun Dec 22, 2024 3:14 pm
