Advise on bond used on garage
Tips, tricks and information on how to spot rogue and cowboy builders and also a platform for you to post and warn others of cowboy builders you may have encountered and help to spread the word of their dodgy dealings
gvperkins
by gvperkins » Wed May 27, 2020 3:05 pm
Hi, I have just had the first 2 courses of a garage laid.
The base is very uneven (shoddy work from a previous builder), so the brick layer advised to lay the first 2 course of block flat, to get a good level surface to work with and then build from there.
However when this has been done using stack bond instead of half bond. Is this strong enough to support the remaining courses and a roof?
image to follow.
Re: Advise on bond used on garage
by stoneyboy » Thu May 28, 2020 10:26 pm
Hi gvperkins
Difficult to understand why stack bond has been used but provided the perps are broken on the next course it should be ok.
Hi gvperkins
gvperkins
by gvperkins » Fri May 29, 2020 11:49 am
Thanks for the response, I decided to take the top course off and lay them again using half bond for piece of mind. Wouldn't want to get half way through the project and then get problems.
It is currently Thu Jan 02, 2025 11:43 am
