How to Repair Loose Bathroom Floor Tile
Chenbas27
by Chenbas27 » Thu May 28, 2020 9:12 am
A tile has come loose from the bathroom floor.There is soil directly below. What's the best way to reattach it?
killy26
Re: How to Repair Loose Bathroom Floor Tile
by killy26 » Wed Jun 03, 2020 8:22 am
There are some tips you can do & repair loose floor tile:
1. Cut the grout around the tile you want to remove and use a chisel or other tool to gently pry it off the floor.
2. Now take either a new tile or, if you’re going to reuse the same tile (in case it’s unbroken), scrape all the adhesive off the tile and the floor beneath it and vacuum any debris.
3. Reapply new adhesive to the new tile and to the floor, set the tile in place, and press it down evenly until it’s level with the surrounding tiles.
4. Grout the area around the tile. After the adhesive has dried (this may take up to 24 hours), your floor should look as good as new!
It is currently Tue Dec 03, 2024 7:34 pm
