Fitting Isolation valve on flexi pipe while fixing leaking tap
Arcdef
by Arcdef » Tue Jun 09, 2020 12:16 pm
Hi all,
I am in need of some advice. I need to do some work to fix my leaking tap and figured now would be a good time to fit an isolation valve to the sink as I currently have to turn off the whole water supply to do any work.
I live in a fairly recent build and the tap is connected via flexi pipes and then to a plastic pipe. Ideally I wouldn't want to cut the pipes if possible and make use of existing fittings but all isolation valves seem to have compression fit and i think i would need a female to male connection (apologies if terminology is incorect).
I have attached an image to help, any advise would be great!
Many thanks,
Ash
Re: Fitting Isolation valve on flexi pipe while fixing leaking tap
by stoneyboy » Wed Jun 10, 2020 9:42 pm
Hi arcdef
The way the plastic has been connected to the flexibles look a bit Heath Robinson.
Suggest you buy a couple of isolating valves to fit in the plastic pipe but don't forget to fit inserts.
It is currently Fri Nov 29, 2024 6:48 pm
