Single or double skin for lignalite blocks for spray booth
FranticBadger
by FranticBadger » Tue Jun 16, 2020 6:38 pm
Just after a bit of guidance on a potential project, to help me work out costs, and generally set me in the right direction.
I'm looking at building a spray booth, measuring 5m wide x 5m deep x 3.5m tall, with a single door measuring 0.7x2m and a large double door measuring 3x3m for forklift access. This would be constructed directly onto a concrete floor inside an industrial unit.
Because the spray process generates a lot of noise, I was looking at using Lignalite blocks, which apparantly have very good sound attenuation properties. These blocks are 440x215x190mm:
https://lignacite.co.uk/products/lignalite/
For this size of construction, should I be looking at a double skin wall? Would this need to be professionally designed? Just trying to get an idea of how much it might cost.
Re: Single or double skin for lignalite blocks for spray booth
by stoneyboy » Wed Jun 17, 2020 12:12 am
Hi franticbadger
The Lignacite blocks should be fine but go for the 7.3Nm ones which will be better for sound insulation and roof loading.
FranticBadger
by FranticBadger » Fri Jun 19, 2020 12:59 pm
Thanks Stoneboy,
So you think a single skin of the 190mm 7.3Nm blocks would be sufficient? No cavity wall?
If so, that's great, that will save me a ton of money, as I'll only need around 650 blocks.
by stoneyboy » Fri Jun 19, 2020 10:40 pm
Hi franticbadger
I don't think you will improve sound insulation by using a cavity wall. Your main noise will be from the extraction system, its ducting and termination.
It is currently Thu Dec 12, 2024 3:44 pm
