Will this tile adhesive be ok for around wood burner insert?
ABev
by ABev » Thu Jun 25, 2020 12:39 pm
I tiled around my fireplace last night with Weber fix plus tile adhesive which withstands up to 100C...I thought that would be ok for what I need it for as I'm not tiling underneath or in the actual alcove that my wood burner will sit in. However, after doing more research AFTER tiling (doh), I'm now starting to worry this won't be any use. Any thoughts? It takes 24 hours to dry fully so if I need to take them off, I'd rather do it today before i fully sets, rather than later. I'm thinking I might only need to redo the ones along the top as they'll be directly above the heat?
Re: Will this tile adhesive be ok for around wood burner insert?
by stoneyboy » Thu Jun 25, 2020 9:51 pm
Hi abev
I don't think anyone will be able to give you a definitive answer.
Why not try it and make remedial work if the tiles become loose.
ABev
by ABev » Thu Jun 25, 2020 11:26 pm
Thanks Stoneyboy, that's what I've decided to do. Fingers crossed! Thanks.
It is currently Thu Jan 02, 2025 2:52 pm
