Advice needed for suspended floor insulation
Coolhwhipp
by Coolhwhipp » Fri Jun 26, 2020 4:39 pm
HI, I'm just about to fit some insulation between the 100mm joists of my ground-level suspended floor from underneath via the crawlspace.
I am currently planning on using Rockwool 140mm with a breathable membrane to hold it in place, rather than Celotex, etc.
The floor above has the original floorboards.
My questions are:
1. Will that be suitable considering there won't be a vapour barrier on the warm side of the insulation?
2. Is there any issue using deeper insulation than the floor joists to boost the U-Value?
Advice would be appreciated :-)
Re: Advice needed for suspended floor insulation
by stoneyboy » Sat Jun 27, 2020 11:27 pm
Hi coolhwhipp
No problem with your proposal, breathable membrane not necessary.
Coolhwhipp
by Coolhwhipp » Sun Jun 28, 2020 11:21 am
Thanks, Much appreciated
It is currently Sat Dec 28, 2024 10:14 am
