Rebate in Wickes standard hardwood door frame
Emlbrouwer
by Emlbrouwer » Fri Jun 26, 2020 10:19 pm
Hi, I have bought a standard hardwood exterior door frame from Wickes. When trying to fit the hinges, I realized the frame has a rebate all along the inside of the frame. It is 2.5mm deep and about 5cm wide, but it doesn't run to the edge of the frame, leaving a ledge that interferes with the hinge. Any ideas why this is? Am I missing something obvious?
Thanks!
Re: Rebate in Wickes standard hardwood door frame
by stoneyboy » Sat Jun 27, 2020 11:44 pm
Hi emlbrouwer
I assume you mean 5mm wide, if yes this is the rebate for a fraught strip.
Emlbrouwer
by Emlbrouwer » Sun Jun 28, 2020 7:13 am
Yes. It is about 5 cm. So I I do fit a draught strip would the hinges fit on top of that? If not, can I chisel the edge away and fit the hinge flush? I am worried that will affect the size of the door opening.. thanks!
M.
by stoneyboy » Mon Jun 29, 2020 11:05 pm
Hi emlbrouwer
The 50mm rebate is for the door to fit into, there may be an additional rebate of about 5mm at the back for a draught strip. Offer up your door and make sure it fits the opening, you will then see how much clearance there is for the hinges.
Hi emlbrouwer
It is currently Tue Jan 07, 2025 1:24 am
