Foundations for garden retaining wall and should I use rebar?
BenD-IY
by BenD-IY » Sat Jun 27, 2020 2:30 pm
Hi all,
I’m a novice DIY’er who is looking to learn. I have a terraced garden and have dug out the slope at the base and now need to build a 2ft retaining wall, 9m long. I was planning on a 35cm deep by 45cm wide foundation and poured concrete looks like a close first vs blocks but still undecided. If I go down the concrete route do I need rebar? If so what thickness? Where should I place it? Should it be 2 lengths in parallel tied to a bar at each end to form a rectangle? Should I put verticals thru the hollow block wall? Thanks in advance.
Ben
Re: Foundations for garden retaining wall and should I use rebar?
by stoneyboy » Sun Jun 28, 2020 9:37 pm
Hi bend-iy
Your option to cast a wall will involve some fairly strong shuttering and rebar and expansion joints. Suggest you use solid 100mm concrete blocks laid on their side effectively giving you a 225mm thick wall with one central expansion joint.
BenD-IY
by BenD-IY » Sun Jul 19, 2020 3:03 pm
Many thanks for the advice, I’ll go with that. Would you put rebar thru the footings or is that OTT?
by stoneyboy » Mon Jul 20, 2020 9:07 pm
Hi bend-iy
Won't hurt to add some in the foundations, use a strong mortar mix for building the wall.
BenD-IY
by BenD-IY » Sat Jul 25, 2020 10:51 pm
Many thanks
It is currently Fri Jan 03, 2025 12:39 am
