Installing metal light with pull switch
mikedry
by mikedry » Sat Jun 27, 2020 2:51 pm
Hi I have a metal light that I am looking to install. I was going to take a cable from my current 2.5mm lighting circuit through a junction box. I have a pull switch that I was going to add. My questions are
-What is the best way to add the pull switch?
-Can I use a ceiling rose without the cover to make the connection at the light bearing in mind it is metal. A full ceiling rose with cover is too large for the metal top of the light to fit over (see pics) I have some 2.5mm cable. Is that ok to use up to the light?
Re: Installing metal light with pull switch
by stoneyboy » Sun Jun 28, 2020 9:45 pm
Hi mikedry
You could use 1mm t&e for your lighting circuit but will have to instal a fused spur. Your pull switch must be fitted in the live circuit and you may be able to use the light pendant cover to protect your ceiling connection.
Presumably you know that this should be done by a registered part p electrician.
by Mr White » Sun Jun 28, 2020 11:35 pm
No "fused spur" required as it is on the lighting circuit, and no Part P registered person required as it is an existing circuit. Sorry about that.
mikedry
by mikedry » Mon Jun 29, 2020 12:02 am
Thanks guys
by ericmark » Tue Jun 30, 2020 10:40 pm
The Maestro Plug In Ceiling Rose slide has a 1/2” BSB female thread to accept a matching tube or threaded hook supplied. Using one of these instead of the existing gives you the standard connections found in any ceiling rose to connect to switch, and means your not holding the weight of the lights while making connections.
It is currently Sat Jan 11, 2025 2:57 am
