New Hot Tub Fuse and Wiring Portable Hot Tub
Statto33
by Statto33 » Sun Jun 28, 2020 10:32 am
I previously had a bit tub professionally wired direct to the fuse box which is on a 32 amp fuse and is RCD protected. I have now purchased a new portable plug and play hot tub which has a 13 amp fuse. Can I cut off the plug and wire directly to the original box outside connected to the fuse box? Would I need to change the fuse box fuse to 13 amps?
Re: New Hot Tub Fuse and Wiring Portable Hot Tub
by stoneyboy » Sun Jun 28, 2020 10:07 pm
Hi statto33
Get an external weatherproof socket fitted supplied from your existing fuse box.
by stoneyboy » Sun Jun 28, 2020 10:08 pm
Hi statto33
Get an external weatherproof socket fitted supplied from your existing fuse box. You may need to replace the existing mcb with a 16A one.
It is currently Sat Jan 25, 2025 6:54 pm
