Repairing Concrete around an outdoor banister
Alfagtv
by Alfagtv » Wed Jul 01, 2020 1:18 pm
Hi There,
I am trying to repair an out door banister.
The upright post is held into the concrete step at its base by 2 anchor bolts.
The bottom anchor bolt has come away from the concrete and there is a hole approx 3 .5 cm deep 2 cm wide.
I would like to fill the whole and replace the anchor bolt to ensure the upright is secure.
I am not sure what materials to use as I have never done this before.
Any advice would be most welcome.
Thanks in advance
Re: Repairing Concrete around an outdoor banister
by stoneyboy » Thu Jul 02, 2020 10:47 pm
Hi alfagtv
Suggest you clear the hole of all loose debris and then fill the hole with one of the 2-part anchorfix which are readily available. You can use the existing anchor if it's ok.
It is currently Fri Jan 03, 2025 3:34 am
