Need help with crack stitching helibars
bokkie
by bokkie » Fri Jul 17, 2020 4:31 pm
Hi all. so I have had a vertical crack appear between front door and landing window. the crack follows the mortar, stepped up, roughly 8 brick courses(60 cm) high.
Had it looked at and it is not structural, so we're all good there.
So I bought a crack stitching kit online to avoid the crack reappearing and have all the necessary tools, but have a couple of questions.
Firstly, it is suggested to space the bars at 45 cm intervals. As the crack is only 60 cm, between a window and door frame, should i just put 1 at the top and one at the bottom, leaving 60 cm between bars. Or should I space them at 30 cm intervals, so 1 at the top, 1 in the middle and 1 at the bottom?
Also, I have read somewhere that it is suggested to rake out to 50mm at the top and bottom of the crack and insert 2 helibars, 1 on top of the other in the raked out mortar. Obviously fixed with the polyester resin compund.
Is this recommended, or would 1 helibar in each be enough, raked to a depth of 35mm?
Thanks all, hope this makes sense
Re: Need help with crack stitching helibars
by stoneyboy » Sun Jul 19, 2020 3:23 pm
Hi bokkie
Suggest you divide crack into 1/4s and fit bars at 1/4 1/2 3/4 positions.
Best to rake out to 50mm below brick face and embed one bar in each recess. Don't forget to blow out all loose material before you inject resin.
It is currently Wed Nov 27, 2024 6:10 am
