Fixing Bench to Solid Wall
aymen_a22
by aymen_a22 » Mon Jul 27, 2020 2:55 pm
I am new to this forum and am looking for advice on fixings to hold a bench to a wall.
I am trying to make and install a bench under a window that will span two solid walls. I am planning to use alength of 38x63mm wood and then use 5mm x 100mm screws with rawl plugs to secure the 2.6m piece of wood to the wall.
Is it "right" to use this type of fixing in this application? Over the 2.6m span I will most likely put screws every 300mm.
It is currently Thu Oct 31, 2024 8:19 pm
