by badger »
Tue Sep 25, 2007 11:45 pm
I'm no heating engineer, but I had the same question myself a few days ago...
So far as I can tell it's there because your pump is powerful enough to create decent flow through all your radiators. When the CH is off the pump would be exerting too much pressure on the relatively light load of the cylinder coil and could well start to push hot water up the vent (gravity system).
The bypass prevents this and has a valve that can be adjusted to regulate the amount of bypass. ie, if the outlet from the coil is pretty much the same temperature as the input, and the tank is heating up fine, there's enough flow through it.
If all that is baloney, no doubt someone will step in and tell us!
