Do you recognise this internal door hinge
Shad512
by Shad512 » Sat Aug 01, 2020 4:07 pm
I need to replace a couple of worn hinges and am struggling to find the name of them. They have a small clip the you lift with a flat blade screwdriver and the door slide out of the hinge fixed to the frame. Really a good idea and so simple to remove the door. Manny thanks in anticipation
Msk
Re: Do you recognise this internal door hinge
by Msk » Sat Oct 17, 2020 11:01 am
I'm sure a 3" national hickman hinge will be a straight swop
It is currently Fri Nov 22, 2024 2:14 am
