Identical replacement part for gate valve
CPHARRIS
by CPHARRIS » Sun Aug 09, 2020 3:06 pm
A common problem with a seized gate valve on 22mm hot water pipe. It won't move and I don't want to shear the stem. Rather than replace the fitting [which is difficult] I thought I may be able to leave the valve body in place and remove the valve stem by undoing the bonnet [it moves ok] and replace it with an identical unit. The gate valve is ~ 30y old marked BS 515[4?], stamped PN20 with the maker's initial, C&P inside a triangle on the body of the valve. I'm looking for an identical replacement please.
Any advice as to the wisdom of what I'm doing and getting the identical replacement would be much appreciated.
Re: Identical replacement part for gate valve
by stoneyboy » Sun Aug 09, 2020 10:46 pm
Hi cpharris
To carry out your proposal you will have to drain down the pipe work - bite the bullet and fit a full flow ball lever valve.
Regards So
CPHARRIS
by CPHARRIS » Sun Aug 09, 2020 11:56 pm
Thanks for your advice. I was hoping to avoid that but 'bullet biting' time has come around I feel.
It is currently Mon Dec 23, 2024 7:13 pm
