Accessing waste pipes for cleaning
DIYNovice4
by DIYNovice4 » Tue Aug 11, 2020 1:36 pm
Many thanks in advance for any advice about this:
If a bath's waste pipe has been soldered or glued in to prevent leaks, rather than being one that can be unscrewed, how can its interior be accessed when it eventually needs to be cleaned to get rid of the hair etc. that accumulates there and can block it?
Kind regards
Nick
blakeriley
Re: Accessing waste pipes for cleaning
by blakeriley » Fri Aug 21, 2020 1:23 pm
Looks like you are gonna have to cut through the glued or soldered part to clean the pipes or it would be better if you could scratch the glue off from the joint and open it up.
DIYNovice4
by DIYNovice4 » Sat Aug 22, 2020 9:19 am
Hi, blakeriley
Many thanks for your help. Doing it myself would be beyond my capabilities. Do you think that's a job a plumber could do inside a few hours, so fairly cheaply?
Kind regards
Nick
It is currently Fri Nov 22, 2024 3:44 pm
