Lath and plaster repair for wall
Libertine
by Libertine » Tue Aug 11, 2020 5:34 pm
My electrician has made some large holes for light switches in the walls. I am not sure the best method to repair this before the plastering is done. The holes are very deep and I am concerned that the wall is weak.
Can suggestions on how best to repair this be given?
Re: Lath and plaster repair for wall
by stoneyboy » Wed Aug 12, 2020 10:19 pm
Hi libertine
If you are getting a plasterer in suggest you leave it to them to make the repairs. Otherwise you could provide a stable background by using expanding foam, coating the lathes and over to the existing plaster. Once the foam has set trim off the excess foam so as th give a decent depth for plastering.
Libertine
by Libertine » Wed Aug 12, 2020 10:29 pm
Thanks for responding. I was not aware expanding foam can be used for this. I know several type of foam are available. What type do you suggest? I did not know expanding foam works as suitable backing.
by stoneyboy » Thu Aug 13, 2020 10:32 pm
Hi libertine
Somehow the lathes and the remaining cement/lime plaster needs to be stabilised before replastering is done. Use a general purpose expanding foam to fill the cavity and cut back the set foam to give a good depth for plastering.
It is currently Sat Nov 23, 2024 3:30 pm
