Fitting architraves and windowsills around window with no recess
Meg0227
by Meg0227 » Thu Aug 13, 2020 3:05 pm
I got new windows fitted but the window fitter didn't leave a recess inside. Now I'm trying to fit architraves and window sills but I'm not sure where they should be fixed against .
When I did some research, I can see there should be a wooden frame sitting on a recess around a window so architrave can be fixed against the wooden frame. But in this case there is no recess , so no place to fit wooden frame.
Can you advise if it's best to fix architrave/windowsills against brick wall in this case ?
Msk
Re: Fitting architraves and windowsills around window with no recess
by Msk » Sat Oct 17, 2020 11:13 am
It can be done, maybe a window board approx 2" thick with 3" projection fixed through the face and a rebated architrave.
The rebate would be the depth equivalent to he distance from the wall to the inside face of the widow approx 5mm by the look of the photos
It is currently Fri Nov 22, 2024 2:24 pm
