Cracking/blistering bathroom wall/lime plaster
Jo1501
by Jo1501 » Fri Aug 14, 2020 12:07 pm
The paintwork in my Mother’s bathroom is cracking/blistering after 3-6months of application. It is a Dulux bathroom paint. The problem walks are exterior. The lime plaster below has previously been patched with a modern filler & sealed. Is the problem due to condensation or the lime plaster reacting with the modern filler/non breathable paint? Is solution to remove existing plaster & replaster from scratch?
Re: Cracking/blistering bathroom wall/lime plaster
by stoneyboy » Sat Aug 15, 2020 9:27 pm
Hi jo1501
If you have lime plastered walls it is likely that they are solid, it is not a good idea to used a non-permeable paint on these wall because damp cannot escape.
Suggest you scrape off an area of blistering and see where the fault is.
It is currently Wed Dec 11, 2024 11:37 pm
