Sealing the cut edge of tiles before re-sealing
Bloodoo
by Bloodoo » Sun Aug 16, 2020 11:22 am
After some 18 months much of the the silicone has let go from where my cut tiles meet the shower tray on the tile edge only, not from the tray.
I have removed the old silicone and intend to clean all accessible surfaces with methylated spirit before re-applying silicone. Do I need to apply tile sealer to the cut edges of tiles to improve silicone adhesion? Will tile sealer damage the tray?
Re: Sealing the cut edge of tiles before re-sealing
by stoneyboy » Mon Aug 17, 2020 9:44 pm
Hi bloodoo
Suggest you use silicone to seal the tile edge - apply with a stiff artists brush, allow to cure then apply the main bead.
Bloodoo
by Bloodoo » Mon Aug 17, 2020 10:03 pm
Thanks Stoneyboy.
I can manage that on the wider gaps but more difficult on the thinner (2mm-3mm)gaps.
by stoneyboy » Tue Aug 18, 2020 9:52 am
Hi bloodoo
On the thinner gaps run a bead of silicone along it and feed this in with a knife blade, clean off the excess and leave it to set. With a gap that narrow nothing will be perfect.
Bloodoo
by Bloodoo » Tue Aug 18, 2020 11:39 am
Thanks Stoneyboy, I will give that a try
It is currently Mon Dec 02, 2024 10:48 pm
