by htg engineer »
Wed Sep 26, 2007 5:12 pm
Is there and have you checked the room thermostat and programmer are calling for heat ?
If they are, are you getting electricity supply to motorised valve (when heating only selected) ?
If yes then it will probably require a new motorised valve. Easy enough to change. Check the 3 port valve spindle moves freely.
REMEMBER TO ISOLATE ELECTRICAL SUPPLY
