Using a thicknesser on lacquered floorboards
mkmly
by mkmly » Wed Sep 26, 2007 1:21 pm
I would like the surface removed from about 20 sq m of lacquered oak floor I have. Ultimately we want a more natural matt or satin wax/oil finish applied.
I'm thinking maybe passing the lot through a thicknesser/planer beforehand or laying it and using a floor sander after. It's to be laid in 2 bedrooms in 2 stages.
Would the factory applied hard lacquer damage the blades or gum up in a thicknesser?
Which is the quickest/best method?
Any advice or thoughts appreciated.
Mark
Oddbod
by Oddbod » Wed Sep 26, 2007 8:25 pm
Hi, I've done worse things to my planer/thicknesser in my time! It won't like it much, and you'll need to resharpen or replace (if disposable) the blades after, but it should do it. Take a little bit more than the thickness of the lacquer off and put new filters in your dust extractor first!
Having said that, a floor sander would easily do the job - albeit at the cost of dust everywhere.
I think I'd go for the floor sander if your other half is out, the thicknesser otherwise!
It is currently Sun Dec 22, 2024 8:47 am
