accessing the pin in danfoss thermostat
alba
by alba » Wed Sep 26, 2007 2:02 pm
I have a cold radiator and am assuming that the thermostat pin may require releasing.
Unfortunately I cannot work out how to remove the outer casing to access this pin.
I think its an older model, but the description is as follows ; black cap on end with danfoss logo, the main part is white plastic which flairs into a skirt shape at the bottom where the numbers are printed. Beyond this is a black plastic ring with a small pointer which superimposes over the number skirt.
Hope this is an adequate description....the point is I can see no screws or apparent means to release the sensor cover and gain access to the pin.
Don.t want to force anything but is it just clip-on? If so what do I hold and what do I pull.
Would be very grateful for advice or input. As a pensioner I can,t afford to pay out £60 for a two minute job if can avoid it.
Excuse rambling post
Thanks in advance
by htg engineer » Wed Sep 26, 2007 5:20 pm
Where the numbers are printed, or maybe just below. This will be where it is connected to the valve. You should be able to turn a part of the valve by hand to release it from the valve.
It's normally a large nut that is just tightened on by hand.
You may need waterpump pliers or something similar if the valves are quite old.
The Heating Doctor
by The Heating Doctor » Fri Sep 28, 2007 9:26 pm
Some Danfoss TRV heads are attached to the valve body via a collar with a allan key, once the allan key is released then the head can be removed as described by htg eng.
