What paint, please, for copper pipes?
7 posts   •   Page 1 of 1
steameraeg
by steameraeg » Thu Aug 27, 2020 5:28 pm
I intend to paint the walls on the under stairs cupboard.
The gas meter and copper gas supply pipes are visible and I'd like to paint the pipes white.
Is there a paint that IS suitable for copper (or is there a type of paint that should NOT be used on copper pipes?)
I'd be very grateful for any advice or help.
CJ
Re: What paint, please, for copper pipes?
by stoneyboy » Sat Aug 29, 2020 10:48 am
Hi steameraeg
Yes to oil based paint eg undercoat, no to water based paint eg emulsion.
steameraeg
by steameraeg » Mon Aug 31, 2020 12:44 pm
Thanks for the info about oil based undercoats, S.
Just as a matter of interest, can you tell me why is this?
I ask because other websites have people who seem to have had good experience of using water based paints.
Cheers and thanks again,
CJ
by stoneyboy » Tue Sep 01, 2020 10:11 pm
Hi steameraeg
The issue with water based paints is that they do not adhere well to non porous surfaces especially if there is condensation likely to form on the pipes.
steameraeg
by steameraeg » Wed Sep 02, 2020 11:29 am
Aha, now I get it!
Thanks again,S, for the help and info, off now to find an oil based undercoat, must have some - somewhere in the garage!
CJ
Marcin2
by Marcin2 » Sun Nov 01, 2020 1:19 am
I have used water-soluble Hammerite primer for non-ferrous metals, outside, covered with the standard Hammerite xylene based product. After two years I cannot find a fault.
My suggestion to OP, would be to use the same primer eg: https://www.duluxdecoratorcentre.co.uk/ ... &v=5084909
than cover it with gloss or satin pain, and only then - if you really have to cover it with emulsion, but bear in mind if you use it on the how water/heating supply - emulsion will crack.
kevinclark
by kevinclark » Mon Oct 04, 2021 9:12 am
Choose A metal paint and primer based on enamel or oil. If you're painting a pipe, make sure both products are compatible. Paints and primers for metal surfaces are generally available in both spray-on and paint-on varieties.
It is currently Sat Nov 23, 2024 3:24 pm
