How to line and insulate my lean to after rebuilding?
CaptainSillyboxes
by CaptainSillyboxes » Tue Sep 08, 2020 9:42 am
Hi all
I've rebuilding a lean-to on the side of my house. It measures 2500mm x 900mm. It has concrete base, 3x2 walls,15mm external cladding, osb roof with rubber covering. Here are photos so far
We are going to put the washing machine and tumble drier in it and I would like to insulate it. I have some 8mm timber t&g to cover the insulation.
It won't have direct heating but will receive heat (and humidity) from the tumble drier and some heat will enter from the kitchen through the cat flap.
Do I need a breathable membrane behind the insulation?
Do I need a vapour barrier in front of the insulation?
Any other considerations I should be thinking about?
thanks!
Re: How to line and insulate my lean to after rebuilding?
by stoneyboy » Wed Sep 09, 2020 10:09 pm
Hi captainsillyboxes
Yes to breathable membrane, yes to vapour barrier and don't forget ceiling.
B4Less
Location: 3rd Floor, 207 Regent Street, London, W1B 3HH
by B4Less » Thu Dec 03, 2020 3:51 pm
Vapour control layers are recommended for use to the warm side of the insulation, it combats the passage of vapour through the wall. Breather membranes are used externally behind the cladding, these protect from wind driven rain while allowing air to pass through. Make sure to use associated tapes to tape and seal both correctly. (Double & single sided tapes)
It is currently Sat Dec 28, 2024 4:44 am
