Plastic Back Box for Flush Fit Thermostat
casman99
by casman99 » Tue Sep 08, 2020 8:53 pm
I'm fitting a flush fit underfloor heating thermostat into a metal back box but noticed that there is no earth wire. I know that metal boxes have to be earthed but all the plastic boxes are for dry walls. Is there anything specific for this situation or should I just adapt a dry wall back box ?
Please help.
Thank you
Re: Plastic Back Box for Flush Fit Thermostat
by Mr White » Tue Sep 08, 2020 10:47 pm
No earth wire from what?
Remote stats are usually double insulated, and the control cable should have an earth.
by ericmark » Tue Sep 08, 2020 11:07 pm
You don't need an earth for separated extra low voltage (SELV) equipment, but for low voltage (230 volt) even if not connected an earth needs running, at one point pre-1966 you could have lights without an earth, but that changed in 1966.
So if mains voltage be it a plastic or metal back box there needs to be an earth.
It is currently Tue Jan 28, 2025 11:07 pm
