Do you recognise these connections?
Alex81
by Alex81 » Fri Sep 11, 2020 5:52 pm
[[/img]
Hello
I wanted to replace the tap of my sink, but I do not know how to undo the connections.
I took a picture.
Do you think I can easily remove them or should i cut the plastic pipe?
thanks
Ale
The picture of the pipe connections
Re: Do you recognise these connections?
by stoneyboy » Sat Sep 12, 2020 11:04 pm
Hi alex81
They look similar to an old version of the Tectite push fit elbows. You will not be able to remove the pipes from them so cutting the plastic pipes is probably the only solution.
It is currently Mon Dec 02, 2024 10:46 pm
