Laying patio but need to build up height first
ritajb24
by ritajb24 » Mon Sep 14, 2020 1:54 pm
Have area 16ftx9ft already dug out with gravel laid as a patio. Want to lay paving slabs but area not high enough. Can I fill it with scalpings to build it up then lay ballast with cement mixture on top instead of sharp sand to lay slabs on and water in
Re: Laying patio but need to build up height first
by stoneyboy » Tue Sep 15, 2020 10:32 pm
Hi ritajb24
Yes you can use scalpings but compact it.
Use a sharp sand mix to lay the slabs on ballast will be useless for getting the levels right.
ritajb24
by ritajb24 » Wed Sep 16, 2020 1:02 am
Thanks for that info , much appreciated S
It is currently Thu Jan 30, 2025 11:59 pm
