Repairing brickwork support above bedroom window
6 posts   •   Page 1 of 1
ady2k5
by ady2k5 » Wed Sep 16, 2020 2:15 pm
I have bought a house and am looking at getting some issues repaired that were raised in the survey report. One is to do with the brickwork support above the bedroom window, it seems to have failed causing the window to sag, pictures are attached.
The report stated that:
The bedroom window has a slight bow, likelihood of being caused the weight of the roof structure bearing onto the window frame and possible deflection of the timber wall plated which supports the roof rafter We recommend inspection of the construction detail and repairs as and installation of lintel as necessary
Is this something that a bricklayer can repair? The report estimated about £700 cost to fix but didn't mention who could repair it.
Re: Repairing brickwork support above bedroom window
by stoneyboy » Thu Sep 17, 2020 9:51 pm
Hi ady2k5
It looks like you are in a relatively modern house so there should be a lintel above the window opening supporting the roof structure. Assuming there is no bowing internally the issue is likely to be wth the window which only has a part row of soldier bricks above it.
The right hand fanlight has sunk badly and suggest you start by replacing the hinges. If this does not disguise the bow suggest you get the window replaced with one with a central mullion to reflect he window below it.
Hi ady2k5
The right hand fanlight has sunk badly and suggest you start by replacing the hinges. If this does not disguise the bow suggest you get the window replaced with one with a central mullion to reflect the window below it.
by stoneyboy » Sat Sep 19, 2020 9:40 pm
Hi ady2k5
Another suggestion which will be cheapest - the setting blocks which should have been fitted at the top and bottom of the centre of the large lower pane of glass are clearly missing. Remove the glazing strips and fit blocks to remove the bow.
ady2k5
by ady2k5 » Sun Sep 20, 2020 1:58 pm
stoneyboy wrote:Hi ady2k5
Hi stoneyboy, thanks for your replies. Is this something the bricklayer or glazer would do?
by stoneyboy » Sun Sep 20, 2020 10:29 pm
Hi ady2k5
Start with a upvc glazing firm and get the window sorted before doing anything more.
It is currently Fri Nov 22, 2024 6:08 am
