Knee space attic insulation
Waters_boy
by Waters_boy » Sat Sep 26, 2020 10:53 pm
Hello. I have a 1.5 storey chalet type property. I’m looking to add additional insulation to the first floor rooms that adjoin the loft space. I’m planning on adding PIR insulation between the uprights of the wall, however I notice there is no insulation between the ground floor ceiling and first floor, and there is space for cold air to come in through the soffits, into the loft space and then straight through the space between the ground floor ceiling and first floor. Should I fill this gap with insulation or leave it open to air flow?
Thank you
Re: Knee space attic insulation
by stoneyboy » Sun Sep 27, 2020 9:41 pm
Hi waters_boy
You should not only plug the void between your first floor floor and the ceiling below but also the ceiling which is outside the footprint of the first floor rooms.
It is currently Sat Jan 04, 2025 11:16 pm
